Won't raise up to level 4??
Old 06-13-2018, 05:02 AM
  #11
Hugo Pedro's Avatar
No fault codes.
no errors, very strange....
Old 06-13-2018, 07:44 AM
  #12
Hugo Pedro's Avatar
The compressor ia a litle bit tired.
what is the normal pressure value the air tank should be showing when the ignition is off and the engine is on?
Old 06-13-2018, 09:55 PM
  #13
amiram's Avatar
Max' 16 bar. But the system can lift the 4 corners to height level 4 also with 10 bar
Old 06-13-2018, 11:04 PM
  #14
Hugo Pedro's Avatar
With the ignition off ir shows 3,4Bar and no goes to 8Bar with pikes os 15Bar
Old 06-13-2018, 11:35 PM
  #15
amiram's Avatar
It is not a problem to fix the compressor . You need only a piston ring (Assuming that the comp' cylinder is not damaged)
Old 06-13-2018, 11:46 PM
  #16
amiram's Avatar
If the system OK (Without fault codes) the compressor will be On only when driving 50 kilometre per hour or more Or in emergency, mean the car sits low on the bumpers
Old 06-14-2018, 08:41 AM
  #17
Hugo Pedro's Avatar
The actual compressor hás the secound repair kit. I’m thinking to buy a new one.
Old 06-14-2018, 09:18 AM
  #18
amiram's Avatar
I replaced the piston rings every year or so. Dose the car sit on the bumpers ? to low
Old 06-14-2018, 10:32 AM
  #19
Hugo Pedro's Avatar
I feel just a slower rise up and nothing more.
it keeps the high mores than one day. I drive evereday and don’t decrease high.
don’t have errors reading with vag com, rise up slower and the strange behaviour is the fact that don’t accept to gongo level IV.
Old 06-14-2018, 08:33 PM
  #20
amiram's Avatar
It is recommended to disassemble the top of the compressor. clean and check sealing rubber bands. Check for air pressure leaks in the air system with soapy water, air springs and air pressure connectors in the valve block and the air springs. The air system works all the time even when you are asleep and always corrects the height until the air pressure is finished in the pressure tank.
Remember, the air pressure sensor in the air spring system checks every time other thing. air pressure tank. Air spring. (every time a different corner). and the valve block to make sure there is no air pressure leakage
Quick Reply: Won't raise up to level 4??
