Won't raise up to level 4??
#43
. In each of the 4 corners. In the pressure tank. And on the red pressure line ( See attached file ) to make sure there are no leaks from this area
#46
I performed the water & soap test and no leaks. I had leaks in the past and the suspension decrease high over nigth. 2 days stoped and didn’t decrease high. Isn’t the g291 sensor who mensure the pressure for the 5 lines?
#47
Yes the G291 is the presure sensor. It is inside the valve block and is not replaceable. I would check the wiring from the valve block or the valve block may need replacing.
#48
Any ideas? The wires seems to be ok. I’ll wait until the weekend and i haver to tale a decision if I’ll take it to AUDI store. It Will be expensive but I need the problem solved.
Chris M.
04-15-2015 07:12 PM
Mark Jacobs
Audi allroad
28
01-25-2013 07:40 AM
Repoman
Audi allroad
10-14-2002 04:35 PM
