Audi Charging System
Old 05-15-2019, 05:08 PM
  #21
2KA6_2.7T's Avatar
Originally Posted by alexlear
I ordered the one from Bernardi since user 2KA6_2.7T confirmed it was a good fit. See the "Accessories" thread. https://www.audiworld.com/forums/aud...ories-2971676/
yes. PERFECT fit. already mounted on teh wall for 2 weeks.
Old 05-15-2019, 05:17 PM
  #22
mjeaton's Avatar
Originally Posted by AudiFan02
Has anyone successfully ordered the wall mount kit? My dealer misunderstood what I was missing and ordered me a new charging pod instead of the wall mount. I might be better off just directly ordering what I need.
Part # 8V4-915-899A
Yes... I found the exact part pictured in the owner's manual. 8V4-915-899-A
Old 05-15-2019, 05:43 PM
  #23
AudiFan02's Avatar
Excellent! This is exactly what I needed.
Old 05-19-2019, 07:48 AM
  #24
mmulet's Avatar
Back to the question originally posted by Traveler29- Is there a way to default the charge to 100%? I'm hooked up to 240V/50amp as well, all the lights flash green - but always have to press the button to change it from 50% to 100%.
Old 05-19-2019, 11:02 AM
  #25
jeffbtx's Avatar
Since you are using 240 looks like the default is 50% - here's what the owner's manual says:
- If a household socket is used for the charging
process, the charging power level is automatically
set to 100%.
- If an industrial socket is used for the charging
set to 50%. To receive the maximum
charging power, the value must be set
to 100%.
When you select 100%, press and hold the selection button for a couple of seconds see if that sets default to 100%. I seem to recall doing that (or something similar) on a Porsche e-hybrid.
Old 07-14-2019, 09:49 PM
  #26
hrc1079's Avatar
Anyone able to figure this out yet. I have an industrial nema 14-50 and always defaults to 50%. I know one night I’m going to forget to change it!
Old 07-15-2019, 05:51 AM
  #27
avie's Avatar
No way to have it default to 100%. It always starts at 50% and you have to manually change it to 100%.
Old 07-20-2019, 07:16 AM
  #28
Krufka's Avatar
Originally Posted by bruinmac
The included EVSE with the e-tron quattro is cheap looking and feeling. Audi cut corners on this one. The ones included with the A3 e-tron and the Porsche SE Hybrids were the same and were higher build quality. I had it sitting outside for 3 years straight and even got rained on occasionally. Still looked good after 3 years. They even have LCD screens that tell you information about charging. This one is just cheap rubberized plastic with LEDs.
Has anyone installed this A3 wall cabinet with new e-tron charger? will it fit inside the cabinet? If so, would you need new bracket 8V4915899A to mount it inside, maybe on some piece of 2x4 to add thickness ? It really looks much better than just bracket hanging on the wall.
for reference parts no.:
CHARGER
Part Number:8V4971675BB
Bracket
Part Number:8V4915899A
Wall Cabinet
Part Number:8V4915706B
Old 07-25-2019, 07:28 AM
  #29
britjonusa's Avatar
Originally Posted by Traveler29
Does anyone know if there is a way from keeping the Audi charging control unit from defaulting to 50% each time I plug into my E1? It is kind of a pain to remember and have to push the button each time to change from 50% (half) to 100% (full) charging power.
Am I missing something... I have the same issue with the charger defaulting to 50% (plugged into 240/50) Non of the buttons on my charger respond?
Old 07-25-2019, 07:50 AM
  #30
avie's Avatar
It always defaults to 50%, no way to change that. To switch to 100% press *and hold* the button for a few seconds.
Quick Reply: Audi Charging System
