Etron charger not working
I have a new etron and wanted to use level 1 charging at home as I dont have a 240v plug yet. When I plug the car in to the provided charger it shows that the waiting for charging timer is on. The problem is I dont have any charging timers on. Called the dealership and the were unable to figure it out. Anyone encounter this and have any fixes for it?
https://www.audiworld.com/forums/aud...usion-2971947/
e-tronforum.com/threads/charging-timer-not-reliable.1237/
Others have had problems with this. On your charger there is an indicator next to the power-on button that shows 50% and 100%. (see page 114 in the owner's manual) Which is lit up on your unit when it's turned on? Pressing the power button again will cycle between the two settings. If the unit is at 50% try setting it at 100%. This apparently has worked at least for some folks.
The following 2 users liked this post by Mike in CA:
jaxjeebers (05-01-2020),
Karldavid (07-18-2021)
Good luck and hope you get your 240v plug installed soon, as I have had no issues with it at all.
I had the same issue when we brought our e-tron home and I was still waiting for an electrician to install our 240v NEMA 14-50 plug (40 amp). Car wouldn't charge on the 120v plug in our garage and tried troubleshooting with the dealership and online. Turns out in the end, based on process of elimination and the vehicle manual troubleshooting page the 120v plug in the garage likely wasn't grounded or there was an issue with the ground causing the EVSE to reject the charge. Apparently the EVSE is very sensitive to these types of things to prevent damage to the batteries. A well grounded 120v plug or grounded GFSI is preferable apparently.
Very interesting. I did most of the wiring in my garage myself with the help of a friend of mine that was a Journeyman electrician in a previous life. The circuit that the plug I was using was connected to is GFCI protected and it passes the plug-in tester's test. I will check the ground, however. The 240v NEMA 14-50 receptacle I installed connects to the same sub-panel and it works no problem, so that suggests there could be a problem with my receptacle and not the charger. I figured it had something to do with the voltage difference making the charger behave differently. This would also support my dealership's contention that it works for them on both 120v and 240v. I can work with this new information and will report back my findings.
I just mentioned this in another thread, before seeing this one. My Audi EVSE, when plugged into a 110V outlet, defaults to 100%. When plugged into a 240V outlet, it defaults to 50% and I have to manually switch it to 100% to get the faster charging. Now, if it’s plugged into 110V and I manually switch it to 50%, the car will display “Waiting for timer”, even though no timer is active. As soon as I switch it back to 100%, charging starts.
BlackOptic (02-28-2020)
My indicator on my Audi compact charger comes on green, then pulses green for few seconds then it turns yellow and shows 50% setting.the manual does not show a yellow/white color for the charge indicator. This is plugged into a 110v outlet. Where are the buttons on the control, are they touch sensitive or give feedback. I am pressing all over the charger and nothing happens. Just received our E-tron yesterday. I have also tried several different outlets including an outside GFI outlet. We do not have our 240v home supply yet.
