How much range are you getting at 80% charged
#11
This is what I'd put my money on. All the Audi marketing materials tout the e-tron's "95kWh" battery. So if the first thing a new owner did was see that at 100% charge they've only got 86kWh available, you know that the dealer will be getting a call about that. Audi could stave that off by including a note on that screen that explains the battery buffers (or perhaps shows all of the values together), but it still creates a recipe for confusion and unhappy customers. A simple 0-100% scale is far more intuitive for the vast majority of owners. Sophisticated folks like us can simply multiply the SoC% by 86kWh to get the actual remaining capacity.
If they were to implement a kWh display, they'd likely have to have it show all three values, something like:
- Top buffer: 3kWh
- Usable capacity: 86kWh (assuming 100% charge)
- Bottom buffer: 6kWh
#15
'19 w/ 20K miles.
184 GOM indicated at 80%SOC w/ ten minutes preconditioning.
If I were to jump on a road trip an needed to eek out 184 miles, I'd charge to 90% SOC and then not sweat the trip on full ADAS at ten over the speed limit with full HVAC.
#16
Institutionalized Member
For reference, at 80% I see between 165 - 200 miles of range in my 2021 e-tron in summer. Winter range is lower (I'm in the Midwest). The higher number is when my recent trips have been in town and I get around 3.0 mi/kWh.
I charged to 100% last night as I have an out of town trip today and the GOM started at 232 miles in my garage and in my 2 mile drive to work (at 30 mph, no AC, windows down) it shot up to 247 miles @ 99% battery. Range estimates fluctuate and are totally dependent on your recent driving. If I'm going to be driving @ 77mph on the interstate with AC on I know I won't get near what the GOM says for my in-town driving.
If you don't have it yet, A Better Route Planner (ABRP) in the App Store is a great app to have. You enter your vehicle, then select other parameters like your cruising speed, outside temperature, and wind speeds (headwind vs. tailwind makes a difference in range) and it calculates what percentage your battery will be at along the way, and will even populate the most efficient charging stops, if needed.
#17
80% has varied between about 140 miles (winter, short trips with waiting in parking lots running heat and defog, one such trip getting less than 1 mile/kWh)
to about 210 miles (Mild weather, long trip, speeds mostly under 60 MPH) (Oh, and one long downhill run with a tail wind from Grand Canyon Village to Holbrook AZ at typical freeway speeds)
GOM is somewhat useful as you get closer to empty. But mostly I look at the MMI charging page showing percentage, and at the MMI "% left at destination" displays.
+1 for using ABRP for trip planning. While it does have some flaws and limitations, it is very useful.
ABRP Flaws:
ABRP Flaws:
- Database of charging stations isn't very good. Use Plugshare, charging network apps/web pages and such to fill in. You can add a waypoint in ABRP and make it a charging stop. Or/or add a non-existing charger into the list of chargers not to use.
- Mapping is based on Open Street Map. Some routes are wrong due to inconsistent quality of OSM. While you can fix these when you find these, you should cross check with Google Maps/ Bing Maps/ Apple Maps/ Waze / Audi app/ MMI navigation.
- Not a very good navigation app.
#18
ABRP Flaws:
ABRP Flaws:
#20
