When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi, anyone have an issue getting the vehicle key into Audi Connect in the MMI. The myAudi app tells me to enter the key information into the MMI, when I go to do this, the "user management" option is not bold and you can't select it.
This happens when Audi Connect is down. It is usually temporary, but it is happening more often. For a technologically oriented auto company, Audi is failing at maintaining a functional back end.
If this is a first time setup, play with the menu selections and set up a PIN (or enter a PIN if you already set it up). Or call AoA 877-505-2834 and tell them you need help setting this up. This is what I did, and wish I had called sooner.
