Error message: "Remote key - replace battery in remote"
An error message about the fob battery popped up on the driver info screen. I have a 2019 so I figure 2 years usage wasn't too bad. I replaced the battery with a brand new #2032 battery and tested the fob - yep, got the blinking light just like the manual says. The next four times I started the car, the error warning was still there. Waited an hour, started the car - no change. How special! Tried the second fob - no error message.
So how do you get rid of a false error message on the info screen?
Have you tried locking and unlocking the car with the fob? If that doesn't work, letting the car fully shut down might help. My dealer said for the car to shutdown fully, not only does the car need to be turned off, but also all windows up and the doors locked. It takes at least 30min for a full shut down.
Also maybe swap the two fob batteries over to test - I had a bad batch of batteries not too long ago and despite changing it 3 times, all 3 were bad out of a strip of 10 batteries
I replaced mine a few weeks back and was just a simple swap and the message was gone. I'd grab another battery and see if that's the issue.
AudiAudiBangBang
There's only one small problem.... now there's a new message that says "License plate light faulty". WTH???
As I noted in the post I did use a brand new #2032 battery. But good news....the car has been shut down for 24 hours and I just started it up and the dead battery message is GONE!
Club AutoUnion
Uh-oh. Did you have the Tail Light Assembly replaced soon after you got your car? I got my 2019MY in Dec 2019 and the first major work done on it was the tail light assembly. The first symptom I noticed was the "faulty license plate light". Go out and look at the car from the rear. Use the Key fob to lock/unlock/etc the car and observe whether the tail light strip does any funky things. Audi had to replace the entire assembly on my car....a very common problem on the 2019MY.
Club AutoUnion
You may want to give them a heads-up before you arrive so they can make sure they have the part in stock. I had to wait a week for it.
