Fried Charger Cable
Old 09-11-2023, 04:55 AM
  #81
Bill33525's Avatar
The fact that the outlet has worked for 9 months without an issue probably indicates something else went wrong. Opening up the box and uninstalling the outlet will reveal whether the wiring went bad. As suggested the screw down could have become loose causing heating at the connection. Checking the wire size for #8 would be prudent as well. You should be able to order a new pigtail for the charger at your dealer. There are a lot of posts on this issue.
geeplus (09-11-2023)
Old 09-11-2023, 04:56 AM
  #82
A4 Phil's Avatar
9 months is a little early for something like this. But to anybody installing a new EVSE.
TIGHTEN the connectors to the outlet. Follow the pattern and ensure that you tighten each screw in order multiple times.
1 MONTH later, re tighten.
Annually re tighten.
This is NOT your 120V outlet in your living room. It will loosen over time. You have to have a solid connection or with that much amperage you will have problems eventually.
ervikingo (09-11-2023)
Old 09-11-2023, 06:23 AM
  #83
rdgrimes's Avatar
Repeated plugging in and unplugging is the most likely cause of a socket fail. Thermal cycles can also eventually loosen something, but not nearly as quickly.
Old 09-11-2023, 09:46 AM
  #84
ervikingo's Avatar
We got a free replacement from Audi as part of warranty for the car.
I test the torque on the connections regularly
Old 09-11-2023, 02:35 PM
  #85
geeplus's Avatar
Originally Posted by thebishman
This is a result of the poor quality outlet installed I’m afraid. You simply have to install a high quality outlet such as the one by Hubbell.
I believe its the poor quality as well, only reason he didn't use my hubbell was the front plate didnt fit my plug.
Electrician actually works for Audi and a few other dealerships installing 14-50s so I trust his work, but his worker failed me with that cheaper option.
Only unplugged it once in 9 months. So I doubt I made it loose with that.
thebishman (09-12-2023)
Old 09-12-2023, 12:06 AM
  #86
thebishman's Avatar
I’m not sure what the replacement 14-50 plug portion replacement from Audi is going to cost you, but if you never unplug and it’s pricey, you might want to consider a hardwired solution from another brand for your EVSE.
Old 09-13-2023, 09:26 PM
  #87
geeplus's Avatar
Service Department Quoted me 479 with tax for the 14-50.
Old 09-14-2023, 12:44 PM
  #88
thebishman's Avatar
Christ, you can almost get a high quality web enabled EVSE for that money! lol
Old 09-14-2023, 10:35 PM
  #89
geeplus's Avatar
Yea Im curious what they sell the full unit for now.
Old 09-15-2023, 09:01 AM
  #90
alex_hobeanu's Avatar
$289.30 + tax for the 14-50 cable at audiusaparts (on-line store of the Beaverton, OR Audi dealership). I ordered few times from them and never had an issue.
https://www.audiusaparts.com/oem-par...bl-7pp971678ed
Quick Reply: Fried Charger Cable
