Homelink Opener - cannot sync
Has anyone been able to successfully program their ETron to connect to the Liftmaster 850 gate opener? I have gone thru the programming sequence a few times and it seems like it's an issue with signal strength. I also had difficulty programming our Cayenne to the same opener but eventually did get it working. My S6 has absolutely no issue with this gate opener.
Same Etron opens our rolling code garage door just fine. I do have an antenna attached to the LM 850 but even that does not seem to be helping. Thinking of getting a signal booster.
Some remotes operate on the same frequency as the lane keeping assist which blocks homelink programming. If so you'd need to pull the lane assist fuse while you program. See attached TSB. It worked for me.
I will share I had 1 opener that really struggled to program (probably related to this), and it took a good 10-15 minutes of constant retries before the system finally got it (but it did, w/o needing to do anything else).
Zoich
Q7 MKII Discussion
39
06-16-2021 10:12 AM
SloopJohnB@mac.com
9
09-10-2019 07:44 AM
shwndh
9
08-15-2019 06:36 PM
dirka3
A4 (B8 Platform) Discussion
11
11-25-2009 10:35 AM
autochicago
03-24-2003 08:46 AM
