Not able to set maximum charge level
hi all,
not sure what I'm doing wrong: I try to set the maximum charge level but the slide keeps going back to the 50% level. I try to use the + signal on the menu or slide the cursor but both ways always give the same result: the screen shows the limit going to 50%. Strangely the car always charge at 100%
any one has experienced this? How to fix this?
I had this issue on a loaner eTron. The MMI max charge setting would not change from the 50% level, but would charge to 100%. The dealer staff couldn't figure it out either. Since it was a loaner I didn't worry about it too much and don't know a fix.
Yes, this is what's happening with my car. The home charger works ok but the issue is with the MMI screen.
The Charging Target can also be controlled by the Advanced Charging Settings ( or the system got confused with your current location)
I will suggest starting with deleting all your Advanced charging settings (locations)
see this for reference
If you have multiple Profiles setup, try remove them and create only a single Profile.
one of the updates that is available right now the Audi Charger is reprogrammed to default to 100% from the factory it defaults to 50% charge rate. You have to push the button on the charger every time until the update is done.
Club AutoUnion
see this for reference https://www.youtube.com/watch?v=vPbfqbEVXC0
I don't have any charging profile and only one driver profile. Let me play with the advance charging settings, maybe I can create one global one that will allow me to set the charging level. I need also to do a SW update for the MMI.
I had this mysterious 'charge to 50%' about a week ago. I had set it previously to 100% before a trip, and when I got to the EA charger, I wanted to adjust it back to 80. It would not let me move it. But the car was at 55, I plugged it in and it charged with no issues until I turned off the charger at 92%. I got to my destination, same thing....50%. I added an advanced setting for current location at 80% and charged. Next day, when I got home, I was able to move the charge once again. I deleted my one advanced setting entry, and i could still move it. Seems like a glitch in their software to me.
Might be worth adding an advanced setting, then waiting till you can adjust, then delete it. Sounds like black magic, but this was the sequence of events I had.
It worked!
After I set up a advance charging profile (for my home address for instance) I was able to set the maximum charge level either while defining the profile or after that on the MMI screen: I could now slide the bar or press the - or + signals.
After that I removed the advance profile and went back to the same limitation. It seems a SW bug, I would expect to be able to setup the maximum charge despite having an advance charging profile. Maybe Audi wants to have always 100% to avoid someone on a long trip to forget setting the charge level to 100%.
In this case I will need to create two profiles: one for charging at home and another one at work both at 80%. All other charges (while on the road) will fall into the 100% limit.
Apollo1403 (04-29-2020)
