2.6l stroker info
I'm looking at doing a 2.6l bottom end for my s4. I was looking at what year 2.5l evrovan crank i would need. I heard that one has smaller jurnals and s cars need the crnak with larger jurnals. So what year crank do i need that has these larger jurnals?
I'm gonna put it in a 7a block with the larger bore and the bottom end is gonna have 2.5 crank in 7a block, pauter rods, and je pistons with 9.5-1 or 9-1, don't know yet.
as well do all 7a blocks have oil sqirters or is thier a specific year that does have it?
Thanks
Thanks
Although I haven't been able to prompt a response in a while...maybe you can. And if you do, please tell him I need the money for my K24.
Chris at devilinsidetunin@aol.com
He even has the blocks if you need them, and has put some strokers together.
Cheers,
Fru-T
Cheers,
Fru-T
cause than i know what went into it and the care that was taken......looking at the negative feedback on the rods...makes me think twice
plus i wanna go with pauter rods and je pistons
I would rather bend a rod then push the crank out of the bottom of the motor. I can show you more pictures of bent carrillo's. Honestly if you are worried about bending like you saw those eagles bent then I must say you are picking the wrong rod. go with an I beam. I have a set of Pauters for another car and after looking at them compared to Carrillo's, Eagles etc... I think they are bottom of the barrel. I have tryied Pauters stuff of and on over the years and can say he can definetly hang good counterweights but I don't trust him to make descent rocker arms or con-rods. If the x rod was a good idea don't you think that auto manufacturers would be using it?
You want to see negative feedback see racers say about Pauter rods and even more Pauter rocker arms.
i was told by a couple people (including dahlback) that i would be very happy with just doing pistons and rods and not an 2.6 stroker.
Consider Dahlbacks rods as well
