92 Rear SwayBar Subframe components and pics, to clear up any confusion.
For the 92 Rear Swaybar R&R you need: The 92 Rear Subframe, the sway bar, the mounts, the bushings, the end links, the end link brackets, and your rear knuckle needs to have this hole tapped into it for the end link bracket.
I believe it is just R&R for the UrS4, I do not know how it is for the UrS6, however from what i have read it should be R&R also.
There are plenty of pics of the entire assembly bolted up in the archives, but these sections aren't documented well so there you have it! =)
<img src="http://img155.imageshack.us/img155/307/img4217hn9.jpg">
The red outlined section is where the swaybar mounts would bolt onto, from the underside.
<img src="http://img155.imageshack.us/img155/9480/img4218vu7.jpg">
Here's the HOLE i was missing on my 93, the end link bracket bolts onto this.
<img src="http://img175.imageshack.us/img175/5096/img4220zz9.jpg">
<img src="http://img169.imageshack.us/img169/7264/img4221au4.jpg">
<img src="http://img166.imageshack.us/img166/4827/img4222jt5.jpg">
So did you drill and tap the "missing" hole? If so, what size drill bit and tap?
I have a 92 cross-member, sway bar and brackets waiting (and waiting for installation in my 93).
No, i grabbed those knuckles from the 92 parts car. They will be swapped on when i get my HRSB
Might get different end link brackets made because when you look at the size of HAP's "beefy" end links they look like they could snap those brackets right off the knuckle on a hard turn!
How was your new years Dave?
Brian
Brian
PSA: Addict Motorsport Design (AMD) in Woodinville WA makes rear crossmember bushings. (See link)
<ul><li><a href="http://www.addictmotorsport.com/urs.html">http://www.addictmotorsport.com/urs.html</a</li></ul>
Isn't the easiest website to navigate. See URL inside for details and pricing.
Yes, straight swap for UrS6. Its a good time to do the wheel bearings.
<img src="http://www3.telus.net/thumbelina/Audi%20S6/Suspension%20Overhaul/DSCF0450.JPG">
