Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
All done...havent gone for a test drive yet..too tired ;)
Old 02-18-2007, 03:02 PM
  #31
es-car-go's Avatar
Default ^^ That is correct and great to know.the 034 RS2 EM replica.
bolts up to a Gen 4 downpipe, as Cody's GT 35 installation confirms!
Thanks
Jeff Posto
posto@comcast.net
Old 02-18-2007, 03:30 PM
  #32
cpayne's Avatar
Confirmed
Old 02-18-2007, 04:31 PM
  #33
UR-Idiot Savant-S6's Avatar
Tell me about it...... both are sitting in my shop. I'll sleep better tonight. 8^)
Old 02-18-2007, 07:03 PM
  #34
Former Vendor
nate @ 034MOTORSPORT's Avatar
Sweetness!!
Old 02-19-2007, 06:51 AM
  #35
cpayne's Avatar
Default There is no way chipping ceramic coating is going to damage the P-Trim Turbine..
The thing could chop wood! Also the inside and NOT the outside is what Javad at 034efi said was the right thing to do. The reason being is that the application of the coatings can be hard on the metal. And if you are going to do one or the other the inside is what to do. I will take his word for it.
Looking at different ceramic coating sites they all mention coating inside of headers, pistons and valves etc:
http://www.jet-hot.com/Pages/tech1.html
http://www.hpcoatings.com/industries/auto.aspx#HI
http://www.hotrod.com/techarticles/engine_coatings_review_tech/
Not sure what might have happened to your buddies coating...
Old 02-19-2007, 11:01 AM
  #36
Guest
VR_Life's Avatar
Default FOD kills turbines
The last guy to have problems used Jet-Hot coatings.
But by all means if you find a revolutionary process that lasts more than a year sounds fantastic.
Bookmarking this post, and we'll revisit it then
BTW: Javad also told me about how loose material from an intercooler was ingested and ended up as little ***** aluminium inside the cats. Great story, but since I've personally lost a Turbo due to miniscule amounts of Intercooler FOD I take these stories only for their entertainment value.
Old 02-19-2007, 11:13 AM
  #37
cpayne's Avatar
Default I had my previous RS2 Manifold Jet-Hot Coated inside and out...NO issues
I dont disagree that FOD can destroy a turbine...most likely a compressor turbine as they are much more fragile. A hot-side turbine..we are talking some thing much more substantial to cause damage then flakes of ceramic material no thicker then a coat of paint.
Here is a pic of the P-Trim Turbine:
<img src="http://pictureposter.audiworld.com/9882/p1010150.jpg">
Here is a pic of the Compressor Wheel on the HO GT35 Hybrid turbo:
<img src="http://pictureposter.audiworld.com/9882/p1010149.jpg">
Here is a pic of the FOD I got on the compressor wheel of unknown material on the previous HO GT35 Hybrid:
<img src="http://pictureposter.audiworld.com/9882/p1010143.jpg">
Here is pic of what happens when you break the turbo shaft in half on a RS2 replica turbo:
Cold Side (Damage from Nut that was on shaft):
<img src="http://pictureposter.audiworld.com/9882/p1010030.jpg">
Hot-Side of the RS2 turbo that ended up in my exhaust pipe (no kidding):
<img src="http://pictureposter.audiworld.com/9882/p1010029.jpg">
Pic of material transfer on hot-side of RS2 housing:
<img src="http://pictureposter.audiworld.com/9882/p1010031.jpg">
Pic of Damaged O2 Sensor by Said Turbine:
<img src="http://pictureposter.audiworld.com/9882/p1010035.jpg">
Pic of where Turbine tried to exit the wall of the downpipe: (See welding patch):
<img src="http://www.worldsbeer.com/urs4/turbo2/P1010159.JPG">
Old 02-19-2007, 12:03 PM
  #38
SilberUrS6's Avatar
Default Huh?
How did stuff from the IC make it to the turbo?
The IC is universally downstream of the compressor, in any turbocharged application I've ever seen.
I can see how stuff from the IC might make it to the cylinders and out to the exhaust (theoretically), but not how IC material dorks up a compressor turbine. Upstream of my compressor, I have the air filter and the MAF (and the piping and housing for that stuff), but nothing else.
Help out a guy, here.
I'm also having trouble seeing how some thin flakes of glass (which is what ceramic is, essentially), are going to do anything to the hotside turbine that would even be visible.
Again, help me out...
dabaTTman
9
12-28-2007 08:07 PM
dabaTTman
A4 (B8 Platform) Discussion
12-28-2007 07:26 PM
DYOS4
08-13-2006 10:05 AM
DM-S4
07-22-2003 06:34 PM
phred
10
07-02-2003 09:24 AM
Quick Reply: All done...havent gone for a test drive yet..too tired ;)
