Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Allowable Movement in Dual Mass Flywheel
Old 11-17-2005, 07:29 PM
quattro20v's Avatar
Default Allowable Movement in Dual Mass Flywheel
I'm preparing to have a shop do a clutch for me, I'm going OEM (Luk) and I have a question about the flywheel.
I picked up a used flywheel from a local lister (thanks, Gabriel) that was newly resurfaced.
With the dual mass flywheel, the two halfs can rotate back and forth slightly, I've heard this to absorb drivetrain shock and vibration when engaging / disengaging.
One thing I'm not sure about is that I can rotate the 2 halfs back and forth about 5 degrees which seems like a lot to me. This works out to about 1.75 inches when measured around the perimeter.
When the clutch is engaged, will this movement cause drivetrain slop?
Would a new flywheel be any different?
Old 11-17-2005, 07:43 PM
MiniMan's Avatar
What made you decide against the Centerforce setup?
Old 11-17-2005, 07:48 PM
New Member
SA urS4's Avatar
Default I just had mine out and I dont remember there being any movement at all
It moved when we were trying to resurface it but I dont think I saw it move any other time
Old 11-17-2005, 07:59 PM
quattro20v's Avatar
Default "OEM is teh best"
Just kidding, I was under the impression that the pedal effort was higher on the Centerforce and its a daily driver and I'm getting old...
Old 11-17-2005, 08:16 PM
MiniMan's Avatar
Default Nobody wants a big left leg...
<center><img src="http://www.edu.rcsed.ac.uk/images/462.jpg"></center><p>
Old 11-18-2005, 02:59 AM
Member
Just-Emre's Avatar
Not true in the least bit. Hell, the Centerfroce uses a lot of OEM bits.
repeater's Avatar
Yarf.
Old 11-18-2005, 03:00 AM
Member
Just-Emre's Avatar
A leg that even a dog in heat wouldn't hump
Old 11-18-2005, 03:02 AM
repeater's Avatar
I thought I was up early.
repeater's Avatar
Nevermind, you're East coast. It's 6 here.
Quick Reply: Allowable Movement in Dual Mass Flywheel
