Any help with Radio code
#11
Radio removal procedures
Oh, oh. Calling in the big "guns" (Dad). Well, *maybe* even Dad will need a bit of help. Can't tell from your 95 S6 VIN whether you have the older narrower Gamma CC or the later wider Delta CC radio.
(reference:
http://www.ibiblio.org/tkan/audi/radios/radios.html )
If it is the Gamma CC, to get it out, you need to cut and bend two pieces of coat hanger into two "square" "U"s (sort of [ and ] only longer, about 1 inch long legs) to go through the two sets of two holes, one on either side of the outside ends of the radion face. Push the "U"s in and it releases to clips on the sides, as shown here:
The wider Delta CC has two 3/8" wide slots in the lower outer ends of the radio face. You need to insert two of special tools shown above (the set of four above) or the less pointer end of these:
through those two slots to retract a spring clip on both sides of the radio, as shown in this TT sterep removal video demonstration:
http://www.youtube.com/watch?v=wlQYb...eature=related
(reference:
#13
Got it! AUZ1Z7R4023881 now the radio wont even read "safe" after pulling it and i was very delicate, any ideas? when the headlights go on all the buttons light up in such.
#15
#17
sidespar
21
07-25-2008 07:34 AM
