Is anyone here running Dahlback software? .....
...Is it similar to MTMs tune (in that the boost peaks then levels off, or is it a steady surge?). I would like to get the version of their software that is the step above mtm stage 3+, but only if it does not require pedal modulation to keep it in the sweet spot.
Its much easier to modulate power. But I'm not comparing apple to apples as the MTM 1+ was with the stock K24 and the Dahlback is with the RS2 turbo.
Interstingly, Dahlback uses MTM code, I found this out when I VAG'd my ECU and MTM popped up.
I've tried BP 370 too, but found the boost and timing too agressive, even with 94 octane and experience pinging. Dahlback still pings, but not as much.
I never tried "real" MTM stage 3 chipsets, so I can't really compare.
...what type of software should I run? Is TJM where you purchased your chipset from? How expensive was the install, if you can remember? Or can I simply just swap out the chips?
icys4
Audi Original "S" Cars
06-23-2008 01:11 PM
Sloooo4esT
11
11-24-2004 03:09 PM
