Anyone make any progress on a D585 bracket?
All required parts should be here by the end of the week, so I'll probably just make something temporary for now. But I'd like a nice clean solution for the long run.
<center><img src="http://pictureposter.audiworld.com/92966/10-23-08_1709.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/s4s6/msgs/247647.phtml">Link to kinderutz's post with pin-outs, photos, etc.</a></li></ul>
You can use a 1/4-20/28 threaded rod if you drill/reem out one of the coil brackets hole as the other one is big enough. 1.5-1.625 inch spacers are about right to keep the assembly as short as possible with 1 inch spacers on the end to go to a bracket/strut bar.
What I'm working on now is location with in my engine bay. There is room near the down pipe, turbo, EM but then again there is a lot of heat there too (I have a lower CF guard on my assembly right now) I've also been toying with a mount over the power steering line that are on the driverside that would come across the IM but I havn't made up my mind yet.
When all is said and done I hope to use Brad Cs fabrication skills (llyod used him I think) to make a nice brackets. Currently he is making me some BBK brackets for 911/928 calipers out of SS.
SQuirelly5
Q5/SQ5 MKII Discussion
05-03-2019 05:03 PM
ePuFFy
10
03-21-2005 05:43 PM
