Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Basic Idle Switch and Throttle Position switch testing (from the Bentley)
Old 08-22-2009, 12:11 PM
UrS4boy's Avatar
Default Basic Idle Switch and Throttle Position switch testing (from the Bentley)
For the Idle Switch (or Closed Throttle Position (CTP) switch):
From pg J 24-64 Bentley Vol 1:
- Disconnect Throttle position (TP) sensor connector.
- Set Multimeter to resistance range
- where Pin 1 of the TP sensor is at the top and pin 6 is at the bottom, connect the multimeter between pins 4 and 6
- Resistance must be 0 ohms (continuity)
- Open throttle valve slightly
- Resistance must be infinite ohms (open).
Checking voltage supply:
Disconnect the harness connector from the TP sensor
- Switch ignition ON
- Connect digital multimeter set to 20 VDC, in turn, between
- Terminals 1 and 2 in harness connector where, with the connector wire "bail" (spring) up, terminal 1 is on the left and 6 is one the right, voltage should be between 4.5 and 5.5 VDC
- Terminals 2 and 3, voltage should be between 4.5 and 5.5 VDC
- If no, check ECU (ECM) and ECU wiring
- If yes, check the resistance of the TP sensor
Checking the TP sensor resistance (from Bentley Vol 1, pg. J24-72):
Where pin 1 on the TP sensor is at the top and pin 6 is at the bottom, with the digital multimeter set to resistance,
- Connect between terminals 1 and 2:
- Must be 1500 to 2600 ohms
- Connect between terminals 2 and 3:
- Must be 750 to 1300 ohms
Measure resistance again while bringing the throttle lever slowly to Wide Open Throttle (WOT) position:
- Must increase to 3600 ohms maximum
If NO (for one or both circuits) - replace TP sensor (PN 078 133 154 - common to many Audi's of the same vintage).
Hope that helps
UrS4boy
05-01-2013 10:59 PM
dtnaughton
03-11-2009 06:01 PM
couper83
03-30-2008 07:51 AM
JazzGuitarist
11-05-2007 03:30 PM
onfir3
04-22-2006 06:08 AM
Quick Reply: Basic Idle Switch and Throttle Position switch testing (from the Bentley)
