been randomly hearing this noise latley
when normal driving at random I hear a whine/whure type sound which I think is coming from the rear of the car, (possible center, cant tell for sure) I hear it when I press gas pedal, sound builds, let off gas, sound fades away. I dont always hear it, at least not yet, and it is very lightly pressing gas pedal when I hear it, not very loud but it is distinct.
what type of sound does fuel pump make, can you hear it when driving, is it dieing
does drive shaft or rear diff. make any noises like this
what could this be
thanks
what could this be
thanks
sounds to me like the rear diff. check the oil level in your rear diff if you can.
The filler should be just in front of the back right driveshaft you will have to take the rear right wheel off to get at it. if oil runs out its obviously full. Normally you should be able to see the oil just below the filler.
you will need a torch and a 10mm allen key to get the filler off
i think mine is dying, but generally you will hear it all the time. if this is the sound change your pump. i doubt it is the rear diff.
I know that my rear diff seal is leaking and was going to replace it and change the tranny and diff fluids thinking that might fix the issue. I dont think it is the fuel pump, as stated we would hear it all the time.
some, but not enough too be concerned, and hes never seen a leaky bone dry or go bad, hmmm
how long have you had this occasional noise?
i've had mine rarely for lil under a month
I have heard this noise for about 2 months now. It has not gotten worse, but I wouldnt mind if it went away with this fluid change
A42.0rgy
08-06-2003 03:33 PM
Flutter sound coming from the rear of the car when accelerating from 2-3.2k RPMs or so... any ideas?
sissupr
06-04-2003 06:02 AM
TTahoe
05-28-2003 08:16 PM
DuTTCH
09-26-2002 03:16 PM
JTravinski
08-02-2001 09:28 AM
