bilstein sprint on OEM springs?
what happens when you have this kind of mod?
on the rs2 there are no rear bilstein shocks that fit excactly on the model.So you get rear from either an S4 (BE3-6212) which you modify to lower the spring setting by 20mm,OR according to a german guy i bought the set from,you get the bilstein sprint rear BE3-2622 for A4quattro sedan,that fits perfectly with no modifications.
...but bilstein says use the sprint shocks with lowered springs!!Do you think i will have any problems with the OEM rear rs2 springs when fitted??
mix heights. I think putting HDs in with shorter springs is worse (more chance of bottoming out the shocks) than putting Sports into stock height springs. I presume "sprint" is close to "sport" in the above suggestion.
would the shock reach its limit before the spring ever does?Is that a bad thing?
bilstein says that HD and sports have the same characteristics in handling,only the height is different
spring pulling up on a shorter shock until the piston on the shock hits the top of the bore. Not good.
Normal driving = probably no problem. Until one day, you hit a big dip in the road = compression (no problem), followed by rebound = BANG! Dude, what's that sound?
zoltannagy
A4 (B7 Platform) Discussion
11-25-2010 09:47 AM
Sloooo4esT
Audi Original "S" Cars
01-01-2004 04:54 PM
alfabutt
9
12-24-2003 08:27 AM
huachele
03-01-2001 07:48 AM
