Car feels very slow
This feels like deja vu, but I'm getting hesitation when accelerating again. Very similar to what I had with my last avant. The car just feels slow 90% of the time. I'll step on the gas in the sweet spot of the RPM range (3-4K) and boost will build quickly, but the car doesn't really 'get up and go' like it should. It doesn't act like a boost leak, since the car pulls like a freight train once in a while (10% of time). If it was a boost leak, or something permanent, it would always act sluggish. Plus, the boost gauge shows that I'm making good boost (23 psi), even when the car is barely accelerating.
Coils/POS - I thought that might be the culprit, so I swapped out the OEM setup and replaced it with 1.8T coils (all R version). I have about 12 1.8T coils in total, so I've swapped coils multiple times to see if one might be going bad, but it made no difference.
The spark plugs, fuel filter, air filter and oxygen sensor have all been replaced within the past 10K miles. Voltmeter shows that I've got 13-14 volts, so alternator appears to be healthy.
Can anyone else think of what might be wrong? Could a weak fuel pump cause this? That's the only thing that I can think of at this point. ARGH!!
FYI - engine mods include: MTM 1+, RS2 EM, Hyperboost BPV, Michelin Man Samco
Adam
Adam
ease into the boost till 3000 rpm and then floor it in 2nd or 3rd, any change? MTM will run rich under boost if you get into it slowly at first
SNogaro4
11-19-2008 06:23 PM
Craigito
08-19-2007 12:26 PM
ViciousCycle74
04-15-2004 05:21 AM
