coil diagnositc help...
#11
the heat much better than the 1.8T coils do. Some people have reported failed 1.8T coils in only 6-8 months after install(IIRC)with the cover over them. However, the coil cover is not needed. Without it I have not heard of the 1.8T coils failing due to heat.
#12
granted they are cheep but I'd rather not deal with an ongoing potentila failure issue. The "high out put" 034 kit looks interesting but at $650 - a single oem replacement seems reasonable.
#13
heat to dissipate to...but I understand that if you want to retain the stock coil cover then it is not a road you want to go down...
#17
Even so this is still is not that good. The 1.8T coils are not attached to the cover so the heat sink property's are lost.
