cold starting problem - intermittent stalling ...
#12
<a href="https://forums.audiworld.com/s4s6/msgs/164792.phtml">https://forums.audiworld.com/s4s6/msgs/164792.phtml</a>
I don't think there is any priming going on if the engine isn't cranked. The 044 pump is loud enough that I'd notice it...
#17
If I read correctly, the car starts every time but stalls some of the time? Or does it just spin the starter sometimes without catching? If it just stalls sometimes, clean your ISV. This was how mine was functioning before I replaced it. The car would fire to 1000-1200 rpm and then just shutoff with no codes.
Make sure you use a lubicating solvent to clean the ISV. I use engine cleaner from AC delco and it works great on carbon deposits. IE: spray it with wd40 after you use brake cleaner.
Hope that helps and its easy to do/check.
Steve
Steve
