Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Could the "over center spring" on the top of the clutch pedal assembly cause a stiff pedal feel?
Old 05-10-2006, 12:20 PM
S6 4RiNGS's Avatar
Default Could the "over center spring" on the top of the clutch pedal assembly cause a stiff pedal feel?
I remember when I had the Centerforce DF clutch put in, the clutch pedal didn't get as light of a feeling as my old 100CSQ did when I changed out the clutch and the spring on the clutch pedal in that car. So my question I guess is, the spring could be the culprit to make the pedal push hard, right?
Part #: 4A0 721 403 D
Old 05-10-2006, 01:50 PM
AudiSport4000's Avatar
Default Heavier duty clutch = "heavy" feeling through the pedal, perhaps?
Alot beefier than the stock clutch stuff.
Ive dealt with 2 over-center springs. One in the 4ktq and one in a 90 20v. The 90's pedal feel was horrible, the over-center spring brought it back to feeling correct.
Old 05-10-2006, 02:19 PM
Guest
VR_Life's Avatar
The spring is there to help pedal-return. Shouldn't significantly impact pedal squeeze pressure
Old 05-10-2006, 02:22 PM
UrScubed's Avatar
Default It could be the clutch, but there are other potential culprits like the clutch slave cyl...
I hadn't realized how heavy the clutch was on my S4 until after the slave failed and was replaced. It took maybe half the effort after compared to before, but I'd never noticed how bad it was since it got worse very gradually.
Old 05-10-2006, 03:40 PM
S6 4RiNGS's Avatar
Clutch has less than 8k miles on it.
Old 05-10-2006, 04:19 PM
Bill the Cat's Avatar
Default Having felt the pedal with no other resistance than the over center spring - twice -
I will say absolutely NO! A little finger's worth of resistance - only to mid stroke.
Past the center of the stroke - the spring will actually help depress the pedal. (Hence - over center.)
JayP
10
02-17-2008 01:01 PM
urs6ville
06-18-2007 01:37 PM
2.7tDallas
08-25-2002 03:12 PM
KenD
01-30-2002 02:18 PM
OldManTan
Misc. Models Discussion
12-15-2000 08:48 AM
Quick Reply: Could the "over center spring" on the top of the clutch pedal assembly cause a stiff pedal feel?
