Crank Bolt Tighting Torque Help !
<center><img src="http://pictureposter.audiworld.com/95326/hpim1677.jpg"></center><p>Hi,
I got the Crank tooth pulley from Gab today and started to put the car back together, I have the crank lock tool and a big Torque wrench, I had everything lined up and Torque the bolt to the spec in My Bentley manual, the first click of the ratchet I stopped and tried to turn the car over by hand .It would not budge, I removed everything again to see if I had the belt jammed up but nothing was out of place.
I repeated the steps again and got the same results (no Movement) So I loosen the bolt and only tightened it to 165 ft lb's and The crank moves freely now .
Is this way to little torque for this bolt or is there anything else I can try, or am missing something here?
Thanks, CMM
Oh Dave the Pictures of the Broken Pulley are in my Picture Poster.
Thanks, CMM
