Current situation - car no start
#22
I assume '208' is all I need to match, yeah?
I have like 5 people looking around the shops for one
are we all in agreement that a failed J17 would cause a running car to stop?
#27
everything is fine, e.g. the engine is turning over AND it is getting a signal from the cam sensor, e.g. during starting with a good Cam sensor and RPMs more than 28 RPM (during cranking).
If the CPS is good and the ECU gets a good signal, the FP relay will be energized through pin 3/55 of the ECU, as Marc S. was pointing you to. However, if the FP relay is dead, then nothing is going to happen.
#29
Maybe your buddy had the wrong relay but the car should have had the 4D0 951 253 (=208)
Kate ref: USA A80q, 1994, MG 9 SG 37 Ill 937-25
