Dave or someone...Coolant Temp gauge is not moving, But the heater
is working. I also let the car idle for about 10 minutes while monitor code 51 on the HVAC display. The display temp rose from 67 to 78 degrees before shutting down the vehicle. MFTS?
Your T-stat is stuck open, keeping the coolant flowing through your radiator which is why you're probably seeing even lower temps than you posted while you're driving on the freeway, etc.
MFTS only controls the signal to you temp gauge. If your coolant temp is actually low, it will show on the CCU (which it did). So MFTS is A-OK.
Cheers,
Cheers,
ducatist4
03-02-2014 07:56 PM
Wren90q
05-07-2004 09:43 AM
Laguna
10
06-29-2001 06:55 AM
evan
01-20-2001 12:03 PM
