Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Diagnosing accumulator failure?
Old 06-18-2005, 06:23 PM
New Member
LastDitch's Avatar
Default Diagnosing accumulator failure?
Just became an owner of a '94 S4 and have spent the last week tending to known issues.
One remaining issue is the brake warning light on the dash(orange circle).
All the pads(and sensor wires) look fine. Is it possible that the accumlator is bad? Is there a code I should look for or some other way to diagnose if it's bad?
Thanks in advance for any help.
Cheers! John
Old 06-18-2005, 06:25 PM
Bill the Cat's Avatar
Default Everything you need to know is here.
<ul><li><a href="https://www.audiworld.com/search/">&gt;&lt;Clickity&gt;&lt;</a></li></ul>
Old 06-18-2005, 06:40 PM
Tech Guru
4Driver4's Avatar
Default That is a very simple light.
All it does is look for continuity through the pad sensors. When it is on it means that the pads are worn enough to break the wire...or there is a problem in the ciruit somewhere else. As Bill says, search on this, and you will find more info.
Test the sensors at each inboard pad for continuity. If they are good, you get to experience the joy of finding an "open" somewhere in the wiring.
Cliff notes:
The orange circle is a pad wear indicator and has nothing to do with hydraulics.
Old 06-18-2005, 07:21 PM
New Member
LastDitch's Avatar
Default Re: Everything you need to know is here.
Thanks for the feedback guys.
I'll check the continuity on all the pads to see if I've got an issue there. I know there could be a fault even though they look fine.
My manual has a section that states, "if both fluid levels are normal, the pressure for the hydraulic brake booster may be low."
It says on a different page, "The brake warning light will light up if the parking brake is pulled and/or the brake fluid level or the hydraulic brake booster pressure is too low."
Maybe I've got my two lights confused, but the manual lists the brake light as two separate items.
I appreciate the patience and the tips guys. Although I'm no stranger to mechanic work on cars, this is my first Audi and I'm sure I'm in for an education! :-)
Cheers! John
Old 06-18-2005, 07:33 PM
jjm's quattro's Avatar
migth be a worth while tip if it wasn't down constantly.
Old 06-18-2005, 07:45 PM
Lane Shark
- GT Style -'s Avatar
That was the old 1, the new works great
Old 06-18-2005, 08:22 PM
Default The bomb is an easy test -
With the engine off - you should get at least 20 power assisted brake pumps - and I would say - a day after it ran would be more of an indication. (but - what do I know? I've never tried it! Works fine to me!)
4driver4 sums up the continuity problem well - just short it out - and look at the pads regularly. (I used a bit of foil in the connector.)
bill the Cat
(Can anyone supply a proper spelling of the Clouseau (Peter Sellers only - please!) pronunciation of 'Bomb'?)
Old 06-19-2005, 04:09 AM
Tech Guru
4Driver4's Avatar
Default The light referred to in the section you quoted is the red "BRAKE" light
The wear indicator light you see comes on *very* early - like when there is 30-40% left.
Old 06-19-2005, 04:43 AM
New Member
LastDitch's Avatar
Default Re: The bomb is an easy test -
Boemb? ;-)
Thanks guys.
Cheers! John
Old 06-19-2005, 07:54 AM
Mr.FRU-T-Pants's Avatar
That's about as close as you can get, I would think. Nice call.
Quick Reply: Diagnosing accumulator failure?
