disassembling exterior door handles
This is a long shot, but does anyone know the right technique and/or tools to remove the outer metal covers from the flush urS car (and others) style exterior door handles? There is a plastic piece that pushes in from the side and retains the metal cover, and there's a tab that needs to be depressed somehow to do it without breaking it.
I'm trying to swap the (other three, pearl) metal plates onto my (black) handles for my pearl 200q20v.
CAUTION!
interior trim must be removed before removing door handle to prevent damage
To remove door handle assembly components:
- Remove door trim panel
- Remove door component carrier - Unhook locking rod for lock cylinder and lock operating rod
To remove, twist toward rear (opposite driving direction)
Twist clamp
Door handle
To remove twist clamp, remove screw
To remove door handle and lock cylinder remove
Packing
Trim plate
Seal
Note:
When tensioned, the ends of the spring must be positioned to left and right of operating lever - Pretensioning will push the operating lever and lock cylinder into center position.
Removing and installing trim cover
Note:
Door handle trim must be removed before removing door handle to prevent damage to paint on handle trim.
Removing
- Pull up door handle.
- Using small screwdriver, pry out locking pin towards rear.
Installing
Install all components in reverse order of removal.
a bit-'o blogging learned me lots-- hopefully helpful, brian
Twist clamp
Door handle
Packing
Trim plate
Seal
Note:
Note:
Removing
Installing
That's the part that seems to be difficult. After I exploded one of them by forcing it, the locking pin looks like it has a tab that needs to be depressed in order to remove it.
Perhaps mine was just jacked up from the forceful disassembly. I'll try the other ones and see how it goes. Thanks for the info!
Bisqueth
03-31-2009 02:24 PM
tree580
09-30-2007 07:20 PM
MichaelTM
17
03-25-2003 02:30 PM
