Do you guys depress the clutch when starting the car?
#12
In the summer, it depends on how I'm feeling.
#13
With the clutch out the starter has to spin the gearbox as well as the engine, that's a fact. This results in unnecessary load on the starter. Specifically during cold starts when the drag is increased even more.
I'm not saying your starter is going to die if you don't press the clutch in, but over time the effect is obviously multiplied. In most situations, there is no reason not to press the clutch for 2 seconds while you start the engine.
Just my $.02
Just my $.02
#16
I think its a bad idea to put pressure on the thrust bearings before oil pressure builds up. If it ends up costing me a starter then so be it, they are much easier to replace.
