Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Does anyone have a pinout for the rear defrost switch (6 pin)? TIA!
Old 01-30-2006, 11:25 AM
MikeL's Avatar
Old 01-30-2006, 01:24 PM
kday's Avatar
Default Sort of...
<img src="http://ultrameta.home.comcast.net/swturbocool/wiring.png">
Old 01-31-2006, 05:35 AM
MikeL's Avatar
Thanks Kev. I'm building your aux.input box and wanted to use a matching switch.
Old 01-31-2006, 06:31 AM
kday's Avatar
Default Oh... the defroster switch isn't the best choice then.
It has a built-in ~10 minute timer. So you'd get 10 minutes of mp3s and then have to hit the button again.
A fog light switch would be better. Best would be to somehow trigger the relay automatically when your aux device is turned on. I did that, but in my case I had an "amp remote" line on the mp3 head unit. Maybe there is a suitable signal on the iPod harness.
Old 01-31-2006, 06:51 AM
kday's Avatar
Default iPod harness...
There is a signal on the dock connector that could be used to trigger the relay, but you would need a transistor to get enough current.
Some info <a href="http://ipodlinux.org/IPod_to_T%26A_remotecontrol_adapter#Short_descript ion_of_the_iPod_Dock-Connector">here</a> on the dock connector.
Run pin 18 to the gate of a FET, use the drain of the FET to switch the ground side of the relay coil. Presto!
Old 01-31-2006, 09:14 AM
MikeL's Avatar
Default I picked up a defroster switch from an older Audi Coupe, found out it does not have timer
part #4A0 941 503 (also took it apart to check)
switch with timer circuit is
#4A0 941 503F
turbos4audi
03-03-2009 01:56 PM
AudiQua
11-27-2008 09:11 PM
Nate (ETKA+Scumbag)
09-05-2005 06:11 PM
ForceFed
9
01-16-2004 12:22 PM
Dr. Bombay
12-08-2001 01:29 PM
Quick Reply: Does anyone have a pinout for the rear defrost switch (6 pin)? TIA!
