Does UrS6 speed limited @ 250Km/H?
<center><img src="http://pictureposter.audiworld.com/96144/s6plusspeedcropped.jpg"></center><p>
As i know that most german Auto is mostly limited
the top speed @ 250 Km/H.So what about our UrS4/S6? Has anyone ever reached over the speed limited with no any modification?
without the speed limiter, a stock UrS6 will do 155 mph (250 km/hr) according to factory testing.
Yours may not have the speed limiter.
due a true 150 mph (about 240 kph) - although the indicated speed will be higher - maybe 250 kph.
With a chip (270 hp) or RS2 conversion (minimum 315 hp) then the top speed will be above 250 kph (155 mph). Its not a linear progression though. Horsepower requirements increase with the cube of the velocity because of aerodynamic drag (for the most part).
Don't try this a home kids. Save it for a LONG track.
Dave F.
Dave F.
which I assume was published in C&D 1992. I just checked that issue and it says 127 mph, but "without the limiter Audi claims the S4 can climb to about 150 mph".
Also, the 1995 Canadian brochure says, Top Track Speed: 241 km/hr, Maximum speed electronically limited to 215 km/hr.
So I supposed 150 mph is the top speed unlimited.<ul><li><a href="http://web.archive.org/web/20030219124215/urs4.com/S4S6/S4S6_performance.html">http://web.archive.org/web/20030219124215/urs4.com/S4S6/S4S6_performance.html</a</li></ul>
hemi is 340 hp and the 6.0 L SRT 8 hemi is 425 hp.
The normal S6 V8 (Europe only) hp was probably about 280 hp, right?
Dave F.
Dave F.
