Driving Impressions--Long
s-heads
Well, early this fine Evahboost morning found me driving the Beast to DIA for a day
trip to San Diego. I am in fact at altitude as a write this missive. I have had
several inquiries about the tubular manifold, the Garrett GT 35R dual ball
bearing turbo, the Turbosmart Wastegate, the adapter I came up with, the install
in general, and my driving impressions so here we go.
The Tubular Manifold:
This manifold was built in Sweden by RS Tuning. We chose mild steel vs
Stainless because of the brittle nature of Stainless in these applications. When
Dave Dawson and I made the first installation attempt, we met with defeat because
the original orientation of the turbo would not allow the the turbo intake to
fit behind the headlight assembly. It seems that Ronnie of RS Tuning had
designed these manifolds for S2/RS2 applications with a parallel to the head mount
and we were very disappointed. I tried to sell the manifold and source
another with no success. Stuck with what I had, I began to engineer. TEC came to the
rescue with a set of machined T3 flange plates that would accept a 2 1/2"
stainless pipe. Next was a 45 degree mandrel bent pipe that could place the turbo
at an angle and further outboard. The pictures I have posted show the
placement. EGTs are significantly lower to the tune of 200-250 degrees. More
observations to follow. Dave has 3 of these manifolds available if you're interested.
His e-mail is:
Djdawson2@aol.com
The Garrett GT 35R Turbo:
Dave Dawson has a GT 30R turbo with mostly stock paraphenalia with the
exception of forged rods and pistons and LWFW. He even has the stock I/C. His turbo
spools at about 4000 rpm but he did see an improvenment when he went from a
.82 ar hotside to his current .63. The GT 35R does not come with a .63 hotside
so I had TEC machine a GT 30R .63 hotside to accept my GT 35R. Since the GT
30/35 turbos come without the turbine housing, this was a simple paperwork fix
but a much more complicated machining challenge. TEC had to model the profile of
my turbine wheel and then machine out the inside of the housing. The results
are outstanding. The boost threshold is about 3-400 rpm higher but the flow is
amazing. I have seen redline pulls of 22 psi in first, and 25 psi in second
and third with no drop off. Simply amazing. Charge air temps are a little lower
but with the Happersized FMIC, its hard to tell a difference. My Davtron I/C
temp gauge's inlet temp probe has been kaput for a while so I don't have any
quantative data on the input side, just the output side. Lower EGTs are
attributable, for the most part, to the new tubular manifold.
Turbosmart Wastegate.
I have had a lot of questions concerning the WG. Like WHY??? Well, our stock
WGs are pretty ugly even if you polish the cap like I had done. Second, the WG
orientation and fabrication of the WG downpipe and its orientation to the
exhaust DP are the hardest part of this type of mod. As I was exploring options
with Jim Latour of TEC, we came up with the Turbosmart WG and its dual V-band
clamp mounting assembly that gives a you 360 degree option to the WGitself and
the WG DP. The BLING factor had nothing to do with this decision. You guys
trust me on this don't you????????????
The Adaptor.
The TEC provided T3 flange plates are stainless. They machined out a 2 1/2"
female receptacle that allows the mounting of the 2 1/2" SS pipe. The pipe had
a 45 degree mandrel bend and about 10" of straight on either end. We ended up
using the entire 45 degrees and made the cut right at the junction going to
straight pipe. Dave also rotated the bend upwards to raise the turbo and give us
the maximum room for placing my current SVT Cobra Snorkel airbox and
PBMAF(Pederhousen Big MAF tm) below the compressor inlet. The bottom of the box is now
2" lower than before and I'm gonna have to do some surgery to cut the bottom
of the box.
General Stuff.
I thought I had everything we needed for Dave to get the install done
starting Friday morning. I had backups and backups to backups. I still ended up
running about 10 trips to Flaps, TEC, and Home Depot. Dave's partner Ian helped all
day Saturday and Ben Howell made several bailout runs with extra odds and
ends. We needed all the extras we had and then some. Check and recheck all your
parts and always have extras. You can always return what you didn't need.
Having a major turbo distributor almost next door is a real plus. If you've got
turbo needs call TEC at 303-271-3997. They can help anyone with your turbo needs.
This type of mod is not for the weak hearted. It really helps to have friends
with lots of expertise and lots of tools. You have to be bale to think and
replan when things can't go the way you originally planned. It really helped
that I already had the FMIC and snorkel intake with the original airbox removed.
I have already posted that it might have been easier had we not had to deal
with my airbox/MAF placement. This type of mod also gets real expensive real
quick.
Driving Impressions.
I was able to flog the car around the hills of Evahboost last night and this
morning, I drove to DIA so my impressions are limited. I can't wait to get
this thing on the dyno and the track. The powah delivery although at a slightly
higher threshold is very linear and the but dyno is severely tested. Its kinda
scary to stay on the throttle. The push is mind numbing. I am guessing a
15-20% increase in my hp/tq numbers. Dave and Mike Pederson have reported a
tendency for tubular manifold cars to die when coming to a stop as they drive along.
I have the same problem. Something familiar yet weird going on here. My custom
dyno tuned Sportec software seems to have held up very well with the new
hardware. I did have to increase the fuel pressure to compensate for the increased
flow with the current A/F at 12.5 with 25 psi of boost. It was really hard
early, 5:00 AM, this morning on the drive to DIA to keep from flogging the car
hard. Big Brakes are very important for survival. My old turbo and RS2 manifold
were impressive but the new stuff is just over the top. The sound is
different. Things are quieter around town and on the highway but the intake howls when
the GT 35 comes on. I need to find somebody locally that can do some sound
bites or better yet video. Yahooooooooo. That's all for now but more will
follow.
Hap, wit lots moh dakine turbo stuff from Evahboos
_______________________________________________
S-CAR-List mailing list
S-CAR-List@audifans.com
http://www.audifans.com/mailman/listinfo/s-car-list
His e-mail is:
Djdawson2@aol.com
The Adaptor.
of the box.
General Stuff.
quick.
follow.
good read im waiting for the dyno :) ill be running a lowly gt30bb with a tubie mani so this has got
me all sorts of excited to hear the linear power (which is what im looking for)
Dave Dawson is runnin the Gt 30R...
He has the very same linear powah. You will be impressed. What manifold are you gonna get???
Hap, wit dakine Qs from Evahboost
i had the same one you are running in my possesion but the fitment like you said
was an issue i was not willing to work around,(love the fab elbow very nice work)
Im looking into either my own but probably javad's 034 efi one which is pretty nice and very nicely priced. ya since i didnt do pistons im looking at 550-500 hp limited so people tell me. The thing i like about the tubular cars like you stated is the egt temps and quick spool hell a rs2 turbo on a tubular mani would be fun as hell but i want more and its all your fault hap you shouldnt go putting this big hp ideas in young easily influenced minds.
Silver Streakin'
01-12-2004 11:32 AM
