Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
EVO question? Is it normal to see black smoke after every upshift?
Old 06-29-2005, 06:33 AM
parkpy's Avatar
Default EVO question? Is it normal to see black smoke after every upshift?
I cannot wait for RS2 stuff. No longer do I think EVO's are super quick.
Paul
-clearly needs brakes after this morning's "commute" to work.
Old 06-29-2005, 06:38 AM
Member
EvanUrS4's Avatar
Pizzo would argue that!
Old 06-29-2005, 07:34 AM
cpayne's Avatar
Pizzo will argue anything
Old 06-29-2005, 07:49 AM
New Member
00zero's Avatar
Default That means the proper breakin instruction were not followed
from what i understand if you do not follow the breakin procedure to the "T" and get on it hard earlly the rings dont seat and they eat oil adn eat it fast.
i have almost 220k on my s4 and it barly eats oil, good ole germans.
-jonathan
Old 06-29-2005, 08:29 AM
spiralsmurf's Avatar
Default if you're seeing a MAF-based car with black smoke on upshifts
he was probably running an atmospheric venting blow-off valve. or his tune is very rich. the blow-off valve causes a rich condition between shifts.
Old 06-29-2005, 08:44 AM
selfproclaimedv8buff's Avatar
Default EVO?! pshhh. Chipped UrS6 >>> 2005 Saleen Mustang
we were toying with it. letting in and out of the gas pedal. how pathetic.
Old 06-29-2005, 09:04 AM
parkpy's Avatar
Default Pizzo's Evo's not stock though, the ones I encounter usually are.
Phew
Old 06-29-2005, 09:07 AM
germantoy's Avatar
Default um no evos run rich if improperly tuned they also do not fatten up with an external blow off
kid probably had a half *** boost/fuel controller and didnt know what he was doing. UNless you were on the highway and that evo was running on 3 cylinders i dont know how it couldnt of beat you.
Old 06-29-2005, 09:09 AM
Stage-3-Emre's Avatar
Thats why none of us on this forum run a BOV, it's common knowledge.
I was going to post that exact response!
Quick Reply: EVO question? Is it normal to see black smoke after every upshift?
