F*&^%$# drain plug!
#13
Couldn't get anywhere with the socket. Ended up driving the trip; which was fine as the oil had actually been recently changed. However, I had to get it on at lift at my mechanic's shop and he was able to loosen it without any trouble. Yep, at that point it taught me why I prefer to work on my own vehicle when I can. And of course to carry spare copper crush washers.
Good luck; you might take it to some quick lube and ask if they will loosen it for you as a guesture of good faith.
#15
Or similar...
Attach to the right sized socket a breaker bar..
Removal is almost instant, no futzing with a hammer and chisel...
BTDT, took less than a minute
#16
I ended up stripping the bolt, and I was really careful to try not to do it. Ended up notching it out with a air grinder and using a 4 ft pry bar to get it off. After that I put on a fumoto valve. Had no problems with it whatsoever.
#17
('94 100S Avant. Green, of course.)
So, I got out my shorty 6-point socket. I put the breaker bar on there, and gave it some hand pre-load. (chefbob's mind furiously spinning on how to attack that collection of words).
Then, I got out my hammer, and started tapping on the shaft of the breaker bar. Not wailing on it, just tapping. After about five minutes of this (it felt a LOT longer), the drain plug broke loose. Then the regular 1/2" drive ratchet finished the job up.
The real fun came when I had to get the filter off. My filter wrench actually twisted the metal casing of the filter. I finally poked two Phillips-head screwdrivers through the casing (all the way through), and broke it loose like that.
It was a bit of a sweat, because a twisted filter could be driven to the mechanic for some shop gorillas to remove. Holes poked through means tow truck if I don't get the damn filter off.
I gave the drain plug a bit of antisieze. The filter just needs to be changed more often.
Yes, I did oil the gasket before I spun the filter on. Always.
#19
If I really gripped it, I could get a full turn. But I've never had leaks.
No, this one was neglect, pure and simple. I thought I had changed the oil at a certain mileage, but what I had actually done was add oil.
So the drain interval had doubled.
The gasket got to be rock-hard and fused itself to the seat.
I've been able to use a filter wrench forever to get VW/Audi oil filters loose. Not this time. And NEVER, EVER put a wrench on the thing to put it one. Hand tight only.
