Fan Clutch... is there a special tool that I can rig up to hold the pulley? I can't get mine off
only works if you are completely replacing your old fan clutch and don't care about damaging it :-)
It's a regular hex key that I shaved on the sides a bit to make it fit into one of the holes on the pulley.
<img src="http://pictureposter.audiworld.com/40606/airport_075.jpg">
<img src="http://pictureposter.audiworld.com/40606/airport_080.jpg">
and the new fan clutch one going in, can't use the tool anymore because there isn't enough space to put it in to the pulley hole... unless you trim it to make shorter which I haven't tried.
<img src="http://pictureposter.audiworld.com/40606/airport_083.jpg">
tehaudi
09-04-2008 07:07 PM
huwla
12-03-2007 08:52 PM
