Feels like hitting brick wall
not the usual issue on WOT but rather, when the engine is cold. When I start the car in the morning, I usually just go but never rev the car past 4K. When I shift to second, car hits brick wall as in a fuel cut off then just goes. It never happens in the higher gears. Mind you it only happens when the engine is COLD.
Thoughts?
Thoughts?
Simple Ignition Maybe
I had a similar whip lash inducing problem, although mine was at WOT. It's a long shot, but worth a try, as I searched for nearly everything else possible before stumbling upon my solution-ignition component. I had a brand new 034 HO DIS Coil System and Ignition cables. In the end one of my new cables was bad. If you have OE setup maybe its something as simple and similar as a plug connector. Good Luck, I know how frustrating the search can be.
-Manny
-Manny
Gap bridged after warm up maybe
Maybe after it's warmed the material has expanded enough to make the connection it can't make when it's cold. Just a guess on my part, but if you have a spare set of plug connectors swap them in and see.
Bubuski
05-11-2005 12:08 PM
Merkin
01-26-2005 01:44 PM
Sergei
12
01-17-2005 10:19 PM
