Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Fun evening....
Old 10-05-2005, 07:54 PM
Junior Member
Julian_B's Avatar
Default Fun evening....
<center><img src="http://pictureposter.audiworld.com/47053/img_0935.jpg"></center><p>
Tonight when i was on my way to drop off the gf, my coolant level light pops up and i get a CEL. IM like holy f*#k specially when my gf tells me there's smoke comming out of the engine. Lucky me i was only a block away from my house so i turned around and put the car in the garage. and turned it off. I let it cool down and filled it back up with water. I immediately noticed the leak. coolant temp sensor housing??? grrr i thought the car was doing soo well, no probs and now this. Oh well at least i found the problem. I checked autohausaz.com and they didnt have the part.4A0 819 497
Old 10-05-2005, 07:57 PM
Junior Member
thermo's Avatar
what'd that part cost ya?
Old 10-05-2005, 08:01 PM
Junior Member
GT500R's Avatar
Default BTDT, very common failure...
Mine broke on the way to the body shop a long time ago when I was originally gonna get my paint job done. Had to alter my plans, it sucked. I suggest these be replaced when vehicle is first purchased, along with timing belt, water pump, oil change, filters, plugs.
Old 10-05-2005, 08:09 PM
Junior Member
Julian_B's Avatar
Default Havent bought the replacement yet since i cant find it
might have to bend over and call the stealership. Yay now i need to get dropped off at work somehow =/
Old 10-05-2005, 08:15 PM
kday's Avatar
Default I bought one at the dealer. Wasn't too bad IIRC.
That's one part I replaced _before_ it failed...
Old 10-05-2005, 08:26 PM
Guest
VR_Life's Avatar
They are very reasonably priced from Stealership
Old 10-05-2005, 08:30 PM
Junior Member
Julian_B's Avatar
Thanx guys, ill call them up first thing tomorrow morning
Old 10-05-2005, 08:54 PM
jjm's quattro's Avatar
5$ from the local stealer - here in H-town
Old 10-05-2005, 09:00 PM
quattro20v's Avatar
Default Happened to me about a month ago. Make sure you replace the other
piece that attaches to the block.
Old 10-05-2005, 10:04 PM
Rexall's Avatar
Default assuming H-town = Houston
Im curious how your car runs down below sea level. I've considered driving mine down from Denver once it gets cold(well... chilly) down there to see what happens. My software was designed specifically for the climate here but swamp-grade humidity matched with the thick air from the (lack of) altitude has got to be nice.
Quick Reply: Fun evening....
