Guys got vibration through steering wheel under semi hard braking?
wheel bolts tight,all seems tight across the steering parts?Just started when i bolted my new avus wheels on?Have i used to much spacer per wheel?would this cause vibration?
Or is it that my pads or discs are worn will have to take a good look.
Damien.
Damien.
<ul><li><a href="http://www.quattronics.co.uk/brakes.aspx">http://www.quattronics.co.uk/brakes.aspx</a</li></ul>
Ive heard bad things about drilled rotors? anyone else? think as Dave said slotted is the way to go.Heard that ferodo DS performance pads really make a huge difference.
I got a question?if you guys over the pond had got the H2 strut brake setup would you have been happy with it?Cannot believe Audi gave u such crap breaks on your S cars from the factory???
Damien.
Damien.
Cayenne's bolt up to the HP2 strut (IIRC) BUT there are rotor issues.
Maybe be he can update us.
