Headlight removal for SAMCO install.
#12
I left the lights in...
The trick I used on the IC to TB - strech the IC end for a couple of hours 0n a larger tubular item - I used a spray can. Dip hose in HOT water - will pop right on.
#13
Done (almost).
I did remove the driver's side headlight, pretty easy with the tips in links below. The hardest part was getting the two lower screws back in afterwards; I used a magnet-on-stick thingy to get them lined up since my fingers don't fit in there well.
I used a little spit to lube the hoses, didn't have to heat any of them up, but it did take some coaxing. I was a little worried about cracking the plastic IC end tanks, since they seem kind of wimpy.
I actually haven't finished the turbo to x-over hose installation yet. I did take the MAF to turbo hose completely out of the car to check for shaft play (very little, even though I had a fair amount of oil in the x-over and lower hoses) and to clean it all up. Also have a new BPV going in (710N package but labelled 710G, D'Oh!).
#16
Whole headlight/turn signal was pretty easy.
I pulled the whole headlamp/turn-signal assembly out, and rested it on a rag on the bumper without unplugging either of the connectors. That allowed me to reach one hand through the hole, and the other from above. Plenty of room to work.
Mbaron
13
11-14-2008 12:40 PM
MP
11-07-2004 03:03 PM
