Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How far is the timing off IF it was set using the mark on the front dampner and not the flywheel?
Old 10-05-2007, 03:55 PM
ImQuattro®'s Avatar
Default How far is the timing off IF it was set using the mark on the front dampner and not the flywheel?
I just read the SJMautotechnik procedure and saw it noted that timing should be set off the flywheel TDC mark.
So how far off is the front mark on the cover/dampner?
TIA!!
Old 10-05-2007, 05:23 PM
|skolnick's Avatar
Good luck finding the flywheel mark. You are fine the way you are.
Old 10-05-2007, 06:06 PM
Stuklr's Avatar
Default Dont use crank pulley
it can be off a tooth in either direction. the crank pulley was never meant to be used on these cars. it happened to me. no damage but stumbled above 5k rpms. mine was one advanced.
Old 10-05-2007, 08:41 PM
ImQuattro®'s Avatar
Default So, are the camshaft dowels supposed to exactly face each other when flywheel is TDC?
<center><img src="http://pictureposter.audiworld.com/15624/camshaft_timing_photo.jpg"></center><p>Seems this topic was already discussed... by me too... hmm.
Just not much info out there on setting up the camshafts w/ the crank or flywheel.
Old 10-07-2007, 07:19 AM
Chad T's Avatar
Default Cams are at TDC....
Now just pull that first spark plug, put a stick down the hole touching the piston and turn the crank back and forth a little bit to find the highest point. Don't spin the crank all the way with no belt on there. Hopefully you're close and don't need to turn it far.
Old 10-07-2007, 09:36 AM
c4S6's Avatar
I'e seen the ellusive flywheel mark. ;^)
Pepper4177
06-15-2009 08:53 AM
Senna4Life
05-29-2006 08:30 PM
Lutz
08-11-2004 09:35 AM
LarryF_in_Ca
07-13-2004 06:08 PM
c4/s4
01-08-2004 04:01 PM
Quick Reply: How far is the timing off IF it was set using the mark on the front dampner and not the flywheel?
