Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
? How to hold the piston in on rear caliper for pad replacement ?
Old 05-27-2004, 05:29 PM
Jason C's Avatar
Old 05-27-2004, 05:43 PM
parkpy's Avatar
Default get the piston retracting tool from Autozone?
Maybe I don't understand the question though. Are you asking how to restract the piston?
Old 05-27-2004, 07:32 PM
selfproclaimedv8buff's Avatar
c-clamp!
Old 05-27-2004, 08:59 PM
ICE RCKT's Avatar
ditto
Old 05-28-2004, 03:43 AM
Tech Guru
4Driver4's Avatar
Default I use a C clamp too, but...
You also need the tool to twist the piston back in. Brute force alone will not do it. I usually try to push the piston back in using just the tool and pushing by hand, If this doesn't work, I put the tool between the c - clamp and the piston, then I turn the tool with pliers as I gradually tighten the clamp. I know some guys just turn the piston with pliers, but this method scores up the piston and can damage the boot.
Old 05-28-2004, 06:49 AM
quattro20v's Avatar
Default I use one of these tools...
<center><img src="http://pictureposter.audiworld.com/52091/dcp01374.jpg"></center><p>works like a charm!
Old 05-28-2004, 06:50 AM
UrSoccer_mobileĀ®'s Avatar
Default I rented one at a local shop for $8 per day..
needs some twisting on the rears.
Old 05-28-2004, 09:00 AM
Jason C's Avatar
Default I just want to swap pads...
thought there was a way of keeping the piston from comming out, or is it just going to happen and I have to get it back in ???
Old 05-28-2004, 09:16 AM
bar1's Avatar
C-clamp and a poly grip.
Old 05-28-2004, 10:47 AM
quattro20v's Avatar
If any local (Vancouver, BC) guys want to borrow it, let me know
Quick Reply: ? How to hold the piston in on rear caliper for pad replacement ?
