Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How-to integrate an aftermarket head unit with stock Bose components
Old 08-05-2008, 05:46 AM
AndrewWK's Avatar
Default How-to integrate an aftermarket head unit with stock Bose components
I decided to go ahead and put together some information for everyone on integrating an aftermarket head unit using the Metra harness. This is using a 1995 S6 Avant with Gamma head unit as an example. I've found alot of FUD regarding integration with the stock Bose components, so I figured it was time to layout the facts.
What you need:
1. Metra 70-1785 harness (for easy connection to Audi harnesses)
2. Head unit with 4x >2.2v preamp outputs (for the Bose amp connections)
3. 2x ground loop isolators (prevents popping on track change)
4. High quality crimp tool (for wiring the Metra to your HU harness)
5. 5x Insulated crimp caps 14-18gauge (for the wiring connections)
6. Audi radio removal tools for your car (to get your radio out)
Head unit suggestions:
1. 4x preamp outputs of 4v
2. ability to turnoff internal amp
3. time-delay configuration for each channel
Some key points to note. You will need to wire your power antenna/remote amp trigger connection to turn on/off the Bose amps with the head unit. The GLI's (ground loop isolators) are connected between the LF/RF/LR/RR pre-amp outputs and the harness connections to each channel on the Bose amps. The GLI's will eliminate the pop when changing tracks by preventing a discharge of the Bose amps, as modern stereos don't use common ground. I got a pair from Bestbuy that seem to do a great job. Here's a picture of the GLI's installed with the Metra harness (this is a 2-piece harness):
<img src="http://pictureposter.audiworld.com/36713/gliupload.jpg">
Only 5 connections in the bottom double Metra harness will be used. They are constant +12v (battery), switched +12v (ignition), illumination, Amp Trigger and Ground. I have also labeled a photo of the harness below. Make sure you twist your wire connections tightly. You can solder them too, if you like. Here is a labeled photo of the diagram on the Gamma unit to show exactly which connections are used for the installation:
<img src="http://pictureposter.audiworld.com/36713/gammalabelupload.jpg">
Backside photo of the 2nd piece of the Metra harness. I removed all the extra wires that weren't needed.
<img src="http://pictureposter.audiworld.com/36713/harnesswiresupload.jpg">
I've built harnesses for a Kenwood with 2.5v pre-amps and the Alpine CDA-9887, which I'm currently using. They both sound excellent with no popping ever (my stock gamma in both cars used to pop occasionally on track changes). The Alpine sounds far superior to the Gamma, especially after configuring balance/fade and the time delay for each channel. I want to try out the Alpine Imprint sound tuning kit with the Bose components. I will update this after I Imprint tune the system to let you know how things turn out, as of right now I see no need to do a Bosectomy. Here's a finished shot (ignore dust):
<img src="http://pictureposter.audiworld.com/36713/installedupload.jpg">
The head unit fits perfectly, as the gamma uses a standard sized opening. It just slides right in and maintains a tight pressure fit. You can use the Crutchfield car configuration function to determine stereos that will fit this opening. I've tried to include everything, feel free to post any comments or questions and I'll update accordingly. See my picposter for a few extra photos of stuff.
Old 08-05-2008, 07:01 AM
Tom (90Carat)'s Avatar
Awesome, thanks!
Old 08-05-2008, 08:53 AM
Linc's S4's Avatar
That new head unit will accept the iPod real easy
Old 08-05-2008, 09:03 AM
AndrewWK's Avatar
Default Crutchfield told me Alpine has the best iPod integration, so I figured I'd check it out
The controls are a bit overwhelming at first, with all the ways to browse and search, but I'm slowly getting the hang of it. The high speed ipod interface is really nice, along with the ability to charge at the same time, and it works great with Touch and iPhone. I routed the cable into the armrest, where the phone used to reside.
I'm debating on if I want to splurge on the bluetooth module and see about wiring in the factory mic.
Old 08-05-2008, 09:31 AM
AndrewWK's Avatar
Default Notes for Delta CC and Concert users
Delta CC and Concert have a different connector and a slight variation in pin-outs. You will also want a faceplate adapter.
Harness:
Metra 70-1787
Faceplate adapter:
Metra 99-9100
You can also run through the Crutchfield "outfit my car" using a 96 S6 and it will show you the correct faceplate and harness adapters. Wiring of the Bose channels and amp trigger are all on the 20 pin harness I believe. The other connections are the same. I will doublecheck and mock-up a diagram if someone is interested.
Old 08-05-2008, 03:47 PM
ImQuattro®'s Avatar
Very nice write up! Great pictures!
Old 08-05-2008, 09:22 PM
c4S6's Avatar
Default Nice writeup; I've added to the FAQ...
Speaking of which... Dave, is there a way to make the FAQ "sticky"??
Old 08-05-2008, 09:46 PM
Lane Shark
- GT Style -'s Avatar
It is, look @ top left of screen
Old 02-17-2009, 09:46 AM
Chapel's Avatar
Default awesome
I'm wondering if I can use part of my old 80-1784 (the Smart Harness version for VWs... looks the same, doesn't have the RCAs) with the 70-1785 RCA bits.
Old 03-01-2009, 09:38 AM
Chapel's Avatar
Default what about Front and Rear antenna?
Mine has two plugs for the antenna?
I didn't see an antenna adapter
Quick Reply: How-to integrate an aftermarket head unit with stock Bose components
