How many hours of labor for a "good" shop to install clutch/flywheel?
#13
I'll tell you, it was one of the easier transmission jobs I've done.
There were a couple hang-ups that took a long time. First of all, the shifter linkage removal, installation, and adjustment is a colossal bitch. The transmission doesn't have enough movement to allow you to totally remove the linkage before you drop the trans, so you have to drop it halfway, tweak the hell out of it, and then remove it. Other than that, I thought the general process of getting to the bolts, driveshafts, etc, was one of the easiest, most straitforward transmissions I've done, it's just because there's so much to do, it's time consuming. I did mine on the ground too, if it makes a difference. With taking my time and doing suspension work (took the struts out, powdercoated the assemblies and changed springs) and some other fun things, it took about 14-16 hours.
#14
Let's just say it's a good thing I don't have an especially wide physique :)
It's just barely wide enough to change tires on both sides of the car, <a href="https://forums.audiworld.com/s4s6/msgs/169640.phtml">but it's a bit tight</a>.
But hey, it beats working outside.
sbmellen
04-12-2007 10:04 PM
SparTTan
Chicago Discussion
11
05-18-2006 05:44 AM
