Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How to reduce turbo lag?
Old 11-07-2007, 09:05 AM
VWinA's Avatar
Default How to reduce turbo lag?
Can you guys comment on those ideas? I have a minor case of turbo lag. It's just annoying but it may be normal. I'm new with my car and don't know exactly what to expect.
-check and tighten spark plugs if necessary
-clean or replace after marked diverter valve with oem one
-check turbo for play and replace if necessary
-change wastegate spring for stiffer one?
-change wastegate diaphragm.
I just have a feeling my car can do better then she does. I recall she had less lag a month ago but the difference is a matter of degrees.
Old 11-07-2007, 09:18 AM
SilberUrS6's Avatar
4.2 V8 conversion.
Old 11-07-2007, 09:20 AM
Junior Member
450exc115's Avatar
Default Cats?
Pluged cats can cause some extra back pressure that may lead to slower spool up..
Old 11-07-2007, 09:23 AM
TabulaRasa's Avatar
7A swap
Old 11-07-2007, 09:49 AM
Mr.FRU-T-Pants's Avatar
Default Not really any of those things are likely the culprit.
I'd check your hoses on the air intact tract, first. MAF to turbo hose a lot of times will rip or crack from age.
Old 11-07-2007, 09:55 AM
|skolnick's Avatar
K03
Old 11-07-2007, 10:11 AM
Herr Schröder's Avatar
Default You don't mean the Roudi Audi do you?
This would cure all. Ford motor, the worlds only '85 type 43 and two titles. She's a beaut Clark...<ul><li><a href="http://carscoop.blogspot.com/2007/06/ebay-roudis-ford-based-audi-5000-suv.html">http://carscoop.blogspot.com/2007/06/ebay-roudis-ford-based-audi-5000-suv.html</a</li></ul>
Old 11-07-2007, 11:46 AM
Bwaha.
Old 11-07-2007, 11:59 AM
tpierce's Avatar
Lawl, 7As have natural lag...
Old 11-07-2007, 12:06 PM
tpierce's Avatar
Default Does it still make full power in the upper rpms?
are you sure the hose hasn't come off the moisture trap?
Quick Reply: How to reduce turbo lag?
