Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
injector recomendation??
Old 04-15-2008, 06:07 AM
New Member
quebecurs4's Avatar
Default injector recomendation??
witch injector you guys recomend.(stock intern) ive got 044 bosh fuel pump,fuel preshure regulator,034 down pipe ,header,gt 30 71 turbo ,stage 3 ,chips,fmic,azot sprinkler,ect . i was running litle bit lean last years with the rs2 injector(replica)
Old 04-15-2008, 08:02 AM
UrS4boy's Avatar
Default People used to find Racetronix (Lucas-Delphi) 37 lb/hr injectors ran rich on RS2 software. This
could be a plus for you.<ul><li><a href="http://www.racetronix.com/621037.html">http://www.racetronix.com/621037.html</a</li></ul>
Old 04-15-2008, 08:19 AM
New Member
quebecurs4's Avatar
thanks for the advice thats what i am running right now
Old 04-15-2008, 08:31 AM
UrS4boy's Avatar
Default FYI: "rs2 injector(replica)" typically means 034's replica injectors, not Racetronix 37 lb/hr.
You probably need something in the 44 lb/hr and then remapping.
Old 04-15-2008, 09:51 AM
New Member
quebecurs4's Avatar
Default 44 lb / boost ?
remaping i was thinking that those mrc chip sets was preset for a certain boost and the motronic still adjust timing /fuel/ ect ,when you run biger injector?
Old 04-15-2008, 10:01 AM
SilberUrS6's Avatar
44 lbs gasoline per hour. Racetronix are 37 lbs/hr.
Old 04-15-2008, 10:22 AM
UrS4boy's Avatar
Racetronix have all sorts of injectors. The ones "we" have used are the 37 lb/hr
Old 04-15-2008, 10:39 AM
New Member
quebecurs4's Avatar
Default i do have those injector#37 lucas/delphi
i did run them last summer it was ok but it was lean little bit! my english it not so good so you did misunderstand me! i have mrc chip set stage 3 and i want to no if the motronic stil modified the timming/fuel/boost if i go litle biger on injector
Old 04-16-2008, 02:06 PM
flyinphil's Avatar
Default Whatever you run, check the tolerances on their fuel flow...
With some injectors there's the possibility of significant variation from one to the next which could have a big effect on tuning - since we typically don't have a WB 02 sensor for each port.
I wouldn't buy anything that didn't have fuel-flow documentation for each injector. I found RC (Russ Collins) Engr had the tightest numbers, and they flow every one. Spendy though.
DAP@EPL
51
03-20-2006 08:33 PM
cpayne
06-15-2005 09:12 AM
2low4snow
12-04-2004 04:58 PM
selfproclaimedv8buff
09-27-2004 09:55 AM
jlh28athome
01-11-2002 07:05 AM
Quick Reply: injector recomendation??
