light throttle ping ? can I log it ? measuring block ?
I've got a new noise (well, it's been doing it a while but I'm getting paranoid) It almost sounds like a slight ping but only when lightly applying throttle and early in the rpm range (it normally doesn't ping at WOT, unless I have a bad batch of gas)
I'd like to log the knock sensors just to see what they're hearing when I go through the eppisode. anyone know the measuring block ?
The load I'm refering to is not related to throttle position. You can have high load at low throttle
Such as if tip into the throttle slightly on an uphill grade or starting off from a stoplight. Light throttle at high load and low RPM are good conditions for knock.
man_utd_4eva_727@hotmail.co.uk
11-22-2016 01:05 PM
Craigito
11-08-2008 08:35 PM
KYNZ
04-29-2007 06:46 AM
Mitch S6 Avant
11-28-2005 06:38 PM
Captain Sheetmetal
12
10-06-2004 03:26 AM
