Mild skip/stutter at full boost....?
If it is that mild then it could be a software or wastegate issue. Try screwing down the...
wastegate screw a couple of turns. If that doesn't clear it up, it could be the waste gate frequency valve.
Or not.
Dave F.
Or not.
Dave F.
YES YOU WILL I GO THROUGH A SET OF PLUGS A MONTH ALMOST LIKE CLOCKWORK
THATS UNDER 28 PSI AND NOT THE BEST TUNING, ITS NOT A COIL CAUSE COILS WILL CAUSE THE CAR TO RUN ALOT WORSE ITS MOST LIKELY THE PLUGS OR IF ITS REALLY COMMON ITS THE POS
Jonny K
Audi Original "S" Cars
16
02-18-2009 08:47 PM
Utah01S4
08-22-2008 12:07 PM
Gotpancit
9
08-02-2007 11:59 AM
bluevr6
9
03-15-2006 12:39 PM
Utah01S4
22
02-22-2006 05:45 AM
