Née brake rotor help
My car has big reds and I found the right pads they are off.a 2000 c4s but the rotors are a different story I tried 4d0615301j too big also tried 8e0615301j and they are the right diameter 12.25 but they are the wrong offset does anyone have a clue? Thanks again in advance mike
The composition of the remainder of the kit can vary a lot. Talk to these folks. They can sort out what you need and provide the parts.
http://apikol.com/
Credit to Trent Wakelin for these part numbers:
RS2 BRACKETS
8A0 615 125 A (034Motorsports or VAG Parts)
993tt Big Red Front Calipers ("Big Reds"):
993-351-425-10 (left), 993-351-426-10 (right)
Porsche 928 GTS front calipers ("Big Blacks"):
Porsche P/N -928-351-423-03 L, 928-351-424-03 R
Later A8 ROTORS (323x30, 5/112)
4D0 615 301 A or J (A was superceded by J)
Also:
Bolts, long (caliper to bracket, x4)
999.067.041.09
Bolt, short (Strut to bracket, x4)
N 100 880 03
Bolt size is: M12x1.25x25mm
Vibration dampers 44 mm (x4)
965 351 096 00
Vibration dampers 36 mm (x4)
964 351 096 01
Wear Sensors (x2)
993.612.368.00
Wear Sensor holders (x2)
928.612.361.00
Brake lines (x2)
443 611 707 C (rubber OEM, M-F, 405 mm long)
Or custom stainless steel
YMMV
I'm not sure how that is helpful. I assume from his measurement (12.25") that he is needing the 314X30 rotors available here. I thought maybe talking to Apikol might help him see all the options.
http://www.ecstuning.com/Audi-C4_S6-...e_2/ES2130105/
Since Mike does not provide any details about the vehicle or the parts he is searching for, there are many other possibilities that might be eliminated by talking to a knowledgable person rather than conducting a guessing game on the forum.
The car is a 1995.5 s6 with Porsche red calipers the pads that work in the caliper are from a 2000 Porsche. My rotors are not the 4do rotors as they are to big in diameter. The 312mm rotors ar th right diameter by the wrong depth? What are some other rotors with the right diameter? Do Porsche rotors fit our cars or are the bbk kits using a8 rotors? Thanks again mike
<img src="http://12v.org/urs/EuroS4HP2Brakes.jpg">
For future reference: "The A8 323X30 rotor has all the same dimensions as the 314, but is available in the states. It fits the same as the 314s.... The rotors have the same offset dimension. The only difference in the rotors is the diameter."
Ref: https://www.audiworld.com/tech/misc42.shtml
