Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Need Help
Old 02-05-2013, 07:56 AM
sanadrustom's Avatar
Default Need Help
so I'm thinking to tackle the job of replacing my control arms and tie rods on my 95 S6. I'm thinking of doing both front and rears. i was wondering if anyone has a link on how to do this and what else i should do at the same time annnnnd what do i actually need? It would be great if i get a part break down on what i need, i researched around but i couldn't find anything definite.
Thank You
Old 02-05-2013, 02:17 PM
UrS4boy's Avatar
Originally Posted by sanadrustom
so I'm thinking to tackle the job of replacing my control arms and tie rods on my 95 S6. I'm thinking of doing both front and rears. i was wondering if anyone has a link on how to do this and what else i should do at the same time annnnnd what do i actually need? It would be great if i get a part break down on what i need, i researched around but i couldn't find anything definite. Thank You
Depends on how much time/money/need you have. You can just do the lower control arms on the front or you can do everything from subframe mounts, to strut bearings, strut mounts, wheel bearings, tie rod ends, etc. etc.
Here is a pdf with torques and some of the part numbers involved.
http://12v.org/urs/FrontSuspensionTorqueValues.PDF
Old 02-05-2013, 06:10 PM
UrS4boy's Avatar
Here are the minimum front suspension parts that you will need:
Item 1 obvisously. Go for OE/dealer parts if possible, otherwise TRW or Febi/Bilstein. We are not liking anything made in China (e.g. Meyle of recent years) - they don't last. Should come with Items 2, 3 and 8 but, if not, you need at least Items 3 and 8.
Items 14 and 15 - both sides, hold the tie-rod end into the strut. Best to go new.
Items 10 and 11. 10 is a sleeve that goes in the end of the lower control arm and often they are rusted. Remove by threading in a wheel bolt (really) and pulling out. Item 11 is a stretch bolt and typically should not be reused.
Old 02-05-2013, 07:05 PM
UrS4boy's Avatar
Parts needed (reference diagram below)
Item 1 obviously. Go for OE/dealer parts if possible, otherwise TRW or Febi/Bilstein. We are not liking anything made in China (e.g. Meyle of recent years) - they don't last. Should come with Items 2, 3 and 8 but, if not, you need at least Items 3 and 8.
When I did my front lower control arms, I took the whole strut out so I had to remove Item 13 that holds the CV joint into the hub. However, I think it is possible to re and re the lower control arm by:
1. Loosening the wheel bolts (5 per side)
2. Jacking the car up and getting it on jack stands on the designated jacking points
3. Removing both wheels
4. Working one side at a time, loosen items 8 and 11.
5. Removing Items 15 and 14. (Note orientation beforehand)
6. Prying the ball joint at the end of the control arm out of Item 25 (use a large pry bar (like 6 ft) on top of the lower control arm and under the subframe, push down, hard.
7. When the ball joint comes out, move the end of Item 25 forward a bit. (Note: If this doesn't work, you might have to loose items 37 to create some slack. If that is not enough, then you might have to also compress the spring with a set of Macpherson strut spring compressors). Your objective is to get better access to Item 8.
8. Remove Item 8, further loosen Item 11.
9. With Item 8 off, use a rubber mallet to "persuade" the ball joint end of the lower control arm to rotate towards the back of the car.
10. Once you have the lower control arm free of Item 20 (the sway bar), remove Item 11 at the subframe end of the lower control arm.
11. Try to pull the lower control arm out of the subframe. It is seems stuck, it is Item 10 ("Sleeve")that is hanging things up. Insert a wheel bolt into the exposed end of Item 10 and use a 17 mm socket and rachet to rotate the wheel bolt into 10 a few threads. Then wiggle and pull on the wheel bolt to remove the sleeve. Once the sleeve is out, pull the old lower control arm out. Note the orientation, you need to get the new left lower control arm on the left side and the right on the right. They are similar but different. Half way there. Now you can do the other side.
12. Once both control arms are out, then you can start re-installing the new control arms. Start with inserting the lower control arm into the subframe mount (in the correct orientation for that side)
13. Insert a new Item 10 through the subframe and into the end of the lower control arm.
14. Insert a new Item 11 through the subframe, through the end of the lower control arm and sleeve and into the subframe mount. Start the threads by hand and then put a few turns on with a socket and rachet.
15. With at least the innermost items 4 and 2 on the Item 20 sway bar, rotate the lower control arm onto the end of item 20. Put the outer items 2 and 4 onto the sway bar and if you have any threads exposed, start item 8. If you have no threads exposed, remove items 8, 4, and 2, and then put just 4 and 8 on and turn 8 enough to move the lower control arm further onto Item 20 sway bar. Then remove Item 8 and Item 4, install Item 2, 4 and 8 and go again, but not necessary as far as possible.
16. Now comes the tricky part, getting the new ball joint on the end of the new lower control arm into the Item 25 wheel bearing housing (strut). This is where loosening items 37 might give you enough flexibility to move the strut around a bit. I sat on a 6 ft pry bar (pipe) (on top of the lower control arm and under the subframe), behind the wheel bearing housing, and used my weight to move the lower control arm down while using my two arms to manipulate the strut over the end of the ball joint. When things look lined up, lighten up on the sway bar prying and let the ball joint go into the strut. Persuade with light taps with a rubber mallet, as needed. Be gentle.
17. Insert new item 14 and add new item 15 nut and tighten.
18. Go to the other side and repeat.
19. When both sides are in, tighten, torque and stretch the new bolts and nuts, eg. Items 11, 14 and 15, 8 and items 37 on the top (if you loosened them). Check your work.
20. Re-install the wheels and lower the car. Torque the wheel bolts to 82 lb-ft.
NOTE: IF the above didn't work for you, the problem probably would have occurred at Step 7. The solution would be to put the wheels back on, lower the car and remove Item 13 that holds the CV joint into the hub. Once the ball joint was out of the strut, removing Item 13 would provide some further flexibility to move the strut away from the lower control arm. I avoided this suggestion at the beginning because Item 13 is a single use bolt and you will need new ones (2) to complete the job. I replaced Items 32 and 36 so I removed the entire strut when I did my lower control arms.
Old 02-05-2013, 10:52 PM
UrS4boy's Avatar
Default Example Parts pricing (one side)
Based on pricing from GVAP in San Diego http://genuineaudiparts.com/partloca...?siteid=214407
Item 1 - 4A0407151 = $181 - Might be available cheaper but don't go to cheap, you will be doing it again in a year or so. Stay with OE suppliers.
Item 10 - 4A0399413A = $23.81 (which is pretty crazy, gotta say)(try to reuse unless totally rusted)
Item 11 - N 90456302 = $7.91
Items 14 - N 0104457 = $2.72
Item 15 - N 0211955 = $1.18
Old 02-07-2013, 12:24 PM
lliejk's Avatar
When I tried to do my rear inner tie rods, I could not get them off the car. When I had the shop do it, they could not get them off the car either. Wound up replacing both the inner & outer tie rod assembly rather than trying to undo the inner tie from the outer.
Parts are expensive and different for left and right side. No idea why.
Ed
Old 02-07-2013, 01:06 PM
UrS4boy's Avatar
Default Rear Camber and Toe adjustment replacement parts
Originally Posted by lliejk
When I tried to do my rear inner tie rods, I could not get them off the car. When I had the shop do it, they could not get them off the car either. Wound up replacing both the inner & outer tie rod assembly rather than trying to undo the inner tie from the outer. Parts are expensive and different for left and right side. No idea why. Ed
If you are going to replace the rear track control rods, you need to start applying Liquid Wrench/PB Blaster, etc about 1 week ahead so you have a hope of getting things off.
They are different left to right because of the direction of the treads on the track control (camber) adjustment nut(s). Here are the PNs for the track control rods:
If you are going to do the toe adjustment brackets, same deal, prep with Liquid Wrench/PB Blaster well in advance. You need items 14 (both sides) and replacements for items 15 and 16 and 35 (Item 35 PN is N 0101977)
Old 02-07-2013, 08:26 PM
scarman's Avatar
If you are considering the inner and outer halves of the upper control arms in the photo below to be the inner and outer tie rod ends, then you want to replace them as a unit. The individual halves are sold separately, but cost more for each half than the entire part.
Old 02-10-2013, 10:05 AM
THANK you guys, some really good info there i appreciate it. i just had a new problem last night i had to brake hard and stop on a dime cause some moron slammed his breaks in front of me, no i get this weird pulsation on the brake pedal and the brake light is on in the dash all the time :s i dunno what it is . Any one got any idea what i'm talking about?
Old 02-10-2013, 10:30 AM
UrS4boy's Avatar
Ever had your ABS come on before?
Quick Reply: Need Help
